View DvR domain redistribution information on a Controller or a Leaf node.
You can view DvR domain redistribution information only on a DvR Controller.
An error message displays if you attempt to view this information on a DvR Leaf node.
Ensure that you enable DvR globally on the node.
View DvR domain redistribution information on a Controller:
Switch:1#show dvr redistribute
DVR Redistribute List - GlobalRouter
SOURCE MET MTYPE ENABLE RPOLICY
STAT 1 External TRUE -
View DvR domain redistribution information for a particular VRF.
Switch:1#show dvr redistribute vrf vrf1
DVR Redistribute List - VRF vrf1
STAT 20000 External TRUE -
LOC 10000 Internal TRUE -
Variable definitions
Use the data in the following table to use the show dvr redistribute command.
Variable |
Definitions |
vrf WORD<1-16> |
Specifies the VRF name. |
vrfids WORD<0-512> |
Specifies the VRF ID of the VRF. |
